kernel: security update to 3.11.10
The Linux Kernel was updated to version 3.11.10, fixing security issues and bugs:
- floppy: bail out in open() if drive is not responding to block0 read (bnc#773058).
- compat_sys_recvmmsg X32 fix (bnc#860993 CVE-2014-0038).
- HID: usbhid: fix sis quirk (bnc#859804).
- hwmon: (coretemp) Fix truncated name of alarm attributes
- HID: usbhid: quirk for Synaptics Quad HD touchscreen (bnc#859804).
- HID: usbhid: quirk for Synaptics HD touchscreen (bnc#859804).
- HID: usbhid: merge the sis quirk (bnc#859804).
- HID: hid-multitouch: add support for SiS panels (bnc#859804).
- HID: usbhid: quirk for SiS Touchscreen (bnc#859804).
- HID: usbhid: quirk for Synaptics Large Touchccreen (bnc#859804).
- drivers: net: cpsw: fix dt probe for one port ethernet.
- drivers: net: cpsw: fix for cpsw crash when build as modules.
- dma: edma: Remove limits on number of slots.
- dma: edma: Leave linked to Null slot instead of DUMMY slot.
- dma: edma: Find missed events and issue them.
- dma: edma: Write out and handle MAX_NR_SG at a given time.
- dma: edma: Setup parameters to DMA MAX_NR_SG at a time.
- ARM: edma: Add function to manually trigger an EDMA channel.
- ARM: edma: Fix clearing of unused list for DT DMA resources.
- ACPI: Add Toshiba NB100 to Vista _OSI blacklist.
- ACPI: add missing win8 OSI comment to blacklist (bnc#856294).
- ACPI: update win8 OSI blacklist.
- ACPI: blacklist win8 OSI for buggy laptops.
- ACPI: blacklist win8 OSI for ASUS Zenbook Prime UX31A (bnc#856294).
- ACPI: Blacklist Win8 OSI for some HP laptop 2013 models (bnc#856294).
- ping: prevent NULL pointer dereference on write to msg_name (bnc#854175 CVE-2013-6432).
- x86/dumpstack: Fix printk_address for direct addresses (bnc#845621).
- Refresh patches.suse/stack-unwind.
- Refresh patches.xen/xen-x86_64-dump-user-pgt.
- KVM: x86: Convert vapic synchronization to _cached functions (CVE-2013-6368) (bnc#853052 CVE-2013-6368).
- KVM: x86: fix guest-initiated crash with x2apic (CVE-2013-6376 (bnc#853053 CVE-2013-6376).
- Build the KOTD against openSUSE:13.1:Update
- xencons: generalize use of add_preferred_console() (bnc#733022, bnc#852652).
- Update Xen patches to 3.11.10.
- Rename patches.xen/xen-pcpu-hotplug to patches.xen/xen-pcpu.
- KVM: x86: Fix potential divide by 0 in lapic (CVE-2013-6367) (bnc#853051 CVE-2013-6367).
- KVM: Improve create VCPU parameter (CVE-2013-4587) (bnc#853050 CVE-2013-4587).
- ipv6: fix headroom calculation in udp6_ufo_fragment (bnc#848042 CVE-2013-4563).
- net: rework recvmsg handler msg_name and msg_namelen logic (bnc#854722).
- patches.drivers/gpio-ucb1400-add-module_alias.patch: Update upstream reference
- patches.drivers/gpio-ucb1400-can-be-built-as-a-module.patch: Update upstream reference
- Delete patches.suse/ida-remove-warning-dump-stack.patch.
Already included in kernel 3.11 (WARN calls dump_stack.)
- xhci: Limit the spurious wakeup fix only to HP machines (bnc#852931).
- iscsi_target: race condition on shutdown (bnc#850072).
- Linux 3.11.10.
- Refresh patches.xen/xen3-patch-2.6.29.
- Delete patches.suse/btrfs-relocate-csums-properly-with-prealloc-extents.patch.
- patches.drivers/xhci-Fix-spurious-wakeups-after-S5-on-Haswell.patch:
(bnc#852931).
- Build mei and mei_me as modules (bnc#852656)
- Linux 3.11.9.
- Linux 3.11.8 (CVE-2013-4511 bnc#846529 bnc#849021).
- Delete patches.drivers/ALSA-hda-Add-a-fixup-for-ASUS-N76VZ.
- Delete patches.fixes/Fix-a-few-incorrectly-checked-io_-remap_pfn_range-ca.patch.
- Add USB PHY support (needed to get USB and Ethernet working on beagle and panda boards) Add CONFIG_PINCTRL_SINGLE=y to be able to use Device tree (at least for beagle and panda boards) Add ARM SoC sound support Add SPI bus support Add user-space access to I2C and SPI
- patches.arch/iommu-vt-d-remove-stack-trace-from-broken-irq-remapping-warning.patch:
Fix forward porting, sorry.
- iommu: Remove stack trace from broken irq remapping warning (bnc#844513).
- gpio: ucb1400: Add MODULE_ALIAS.
- Allow NFSv4 username mapping to work properly (bnc#838024).
- nfs: check if gssd is running before attempting to use krb5i
auth in SETCLIENTID call.
- sunrpc: replace sunrpc_net->gssd_running flag with a more
reliable check.
- sunrpc: create a new dummy pipe for gssd to hold open.
- Set CONFIG_GPIO_TWL4030 as built-in (instead of module) as a requirement to boot on SD card on beagleboard xM
- armv6hl, armv7hl: Update config files.
Set CONFIG_BATMAN_ADV_BLA=y as all other kernel configuration files
have.
- Update config files:
* CONFIG_BATMAN_ADV_NC=y, because other BATMAN_ADV options are all
enabled so why not this one.
* CONFIG_GPIO_SCH=m, CONFIG_GPIO_PCH=m, because we support all other
features of these pieces of hardware.
* CONFIG_INTEL_POWERCLAMP=m, because this small driver might be
useful in specific cases, and there's no obvious reason not to
include it.
- Fix a few incorrectly checked [io_]remap_pfn_range() calls (bnc#849021, CVE-2013-4511).
- Linux 3.11.7.
• https://bugzilla.novell.com/show_bug.cgi?id=859804
• https://bugzilla.novell.com/show_bug.cgi?id=852931
• https://bugzilla.novell.com/show_bug.cgi?id=733022
• https://bugzilla.novell.com/show_bug.cgi?id=773058
• https://bugzilla.novell.com/show_bug.cgi?id=854722
• https://bugzilla.novell.com/show_bug.cgi?id=852656
• https://bugzilla.novell.com/show_bug.cgi?id=838024
• https://bugzilla.novell.com/show_bug.cgi?id=856294
• https://bugzilla.novell.com/show_bug.cgi?id=849021
• https://bugzilla.novell.com/show_bug.cgi?id=854175
• https://bugzilla.novell.com/show_bug.cgi?id=845621
• https://bugzilla.novell.com/show_bug.cgi?id=860993
• https://bugzilla.novell.com/show_bug.cgi?id=848042
• https://bugzilla.novell.com/show_bug.cgi?id=853052
• https://bugzilla.novell.com/show_bug.cgi?id=853051
• https://bugzilla.novell.com/show_bug.cgi?id=853050
• https://bugzilla.novell.com/show_bug.cgi?id=853053
• https://bugzilla.novell.com/show_bug.cgi?id=852652
• https://bugzilla.novell.com/show_bug.cgi?id=850072
• https://bugzilla.novell.com/show_bug.cgi?id=846529
• https://bugzilla.novell.com/show_bug.cgi?id=844513
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2013-4587
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2013-6367
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2013-6376
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-0038
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2013-6368
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2013-4511
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2013-4563
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2013-6432
Ein Neustart des Rechners wird für die Übernahme der Änderungen der Aktualisierung erforderlich.
Paketquelle: repo-update
